vladimir_ivanov93
596 Vistas, 8 Respuestas
No ”Insert field...” option in the ”Formula” box?
Hi!
   How do I insert a field in the formula box of the AutoCAD for MAC (2024)? There is no such options like the one in the AutoCAD version for Windows.
Thank you!
pendean
en respuesta a: vladimir_ivanov93
@vladimir_ivanov93 hard to tell out of context like that what the MacOS screenshot is referencing, the #### in the preview section would indicate nothing was selected... .
vladimir_ivanov93
en respuesta a: pendean
I am talking about the drop-down menu in the formula box. There is no “Insert field…” option.
paullimapa
looks like you may have discovered another missing feature in the Mac version
Paul Li
IT Specialist
@The Office
vladimir_ivanov93
en respuesta a: paullimapa
But this one is quite major. I was not able to create the desired attribute, at least I didn’t know how to, without inserting a new field in the formula. I ended using Windows just for this task and then return to Mac.
paullimapa
Well, looks like you have a decision to make.
If you need to continuously use this particular feature, then you may have no choice but to go back & forth or just stay with the Windows version.
Paul Li
IT Specialist
@The Office
Ok. Let's consider a situation like this (a very good example): https://www.youtube.com/watch?v=6wc_W7q4OqA . How do I create this attribute without using "Insert field..." (the one from the formula box, not the one from attribute field). There must be a workaround. I am sure it can be done hard way, but I would like to know how.
maxim_k
Hi Vladimir!
@vladimir_ivanov93
Yes, this feature is not available in AutoCAD for Mac, but there is workaround:
you can prepare the Formula field contents outside AutoCAD and then use it in AutoCAD.
Please look at how-to video:
Have to say, that there is a bug in AutoCAD for Mac related to the Formula fields created with "insert form context menu" method (on PC) or created with workaround I show above - you cannot edit such Fields. In order to make changes to such Fields you need to recreate them from scratch.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
vladimir_ivanov93
en respuesta a: maxim_k
Thank you very much! That is very nice and useful. Great workaround! :manos_aplaudiendo:
