liamrobertsSP
en respuesta a: maxim_k
Hi @maxim_k
The block you sent me works great, thanks for that, the only issue is when I stretch it sometimes it leaves the parameter grips behind, as in they do not move with the center of the block. Sometimes they are off (by the length of the stretch) in the other direction. Like in the Screenshot below.
Also when I insert it from the block library the attributes for dimensions do not update upon regen. This will only work if I copy and paste the block within the drawing.
Liam
