01-25-2024
12:08 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-25-2024
12:08 AM
You can try to remove all Parametric constraints: use menu Tools -> Parametric -> Delete Constraints.
When AutoCAD will ask to select objects, you can select rectangles and hit Return.
If you want to delete all constraints in the drawing, type ALL and hit Return when AutoCAD asks to select objects.
If you don't want to automatically apply geometric constraints while creating and editing geometric objects, verify that system variable CONSTRAINTINFER=0 from the command prompt or by looking at the Status Bar toggle:
Maxim Kanaev
Architect
MARSS
