01-18-2024
11:34 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-18-2024
11:34 PM
Hi @roger3PGF4 ,
Set sytem variable GRIPMULTIFUNCTIONAL=1
Now when you select grip by picking on it use Ctrl key to cycle between MF Grip options - just look at the command window which option is active.
For polyline middle segment grip you should see:
Command:
** STRETCH ** <--press Ctrl key
Specify stretch point:
** ADD VERTEX ** <--press Ctrl key
Specify new vertex point:
** CONVERT TO ARC **
Specify midpoint of arc segment:
Command:
Maxim Kanaev
Architect
MARSS
