- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
having issues with paper space, can't find Autodesk Documentation, blogs or frum threads to assist me
when I create a new layout view in my drawing and set the page setup scale to 1:1 and the drawing viewport scale to 1:10, the model (which is at 1:1) is showing at a scale very different to 1:10.
I have one Layout with is setup as an A3 landscape format, and the view mode is set to reflect the plot style choose for the layout (monochrome: lines of all colours printed as solid black). The scale for this section drawing is 1:2, and the scale looks accurate to me given the 420x297 mm page dimensions.
When I click on the viewport of this correctly working Layout, I get some info in the top left corner (see image)
When I use the pan command, Autocad moves the drawing within the viewport window so I can get the correct part of the drawing from modelspace inside my paperspace boundaries.
when I duplicate this Layout then click on the viewport, it highlights in a different way, with coloured selection anchors on the corners. When I pan the whole layout page moves, not the contents of the viewport in relation to the page. When I double click the viewport boundary Autocad goes into a modelsapce like mode and pacing and zooming here makes no difference when I leave the modelspace/viewport view. Also all the lines are in their layer colours not the plot style monochrome assigned to the Layout in the Layout this was duplicated from.
I have the same issues creating Layouts as new by clicking the "+" button in the lower left corner of the Autocad window next to the existing layouts. But it gets worse. This is where I'm seeing drawings that are set to 1:10 appearing more like 1:200 or something. The scale is totally out. can't get the ploy styles to apply again, I must of flaked it with the one sucessful elevation.
Looking for a friend, or failing that some decent documentation from Autocad. Even the "master Autocad Papersapce blogs I've read shine zero light on these problems I'm having"
