alastair_leith
en respuesta a: alastair_leith
thanks. I had forgotten I'd redefined the block to contain no objects so as to avoid using the wrong block by mistake. So wasn't visible until I did a Quick select command.
the other one is referenced inside the block that replaced it. this will be more tricky to fix I expect!
