alastair_leith
2151 Vistas, 4 Respuestas
How do I delete a block listed in the blocks palette from my drawing?
I have a block defined in my drawing which I wish to delete (calling it OLD_BLOCK for this Q).
  • It's a user defined block as far as I know (FAIK), as I created it inside the drawing using the a BLOCK command.
  • It has a really similar name to a new BLOCK (calling it NEW_BLOCK) that I since created to replace all instances of OLD_BLOCK (yes I should have just edited the OLD_BLOCK but I didn't)
  • I have deleted all instances of it in the drawing (FAIK)
  • I did a purge
  • now I want get rid of the listing and all reference to this block so I don't have to parse two similar names ad chose the correct one.
I can't find any reference in Documentation to deleting a block definition.
I can't use the BLOCK text command, it insists on opening the semi-GUI dialogue box for defining a new block. I tried _BLOCK but it still opens the same modal window.
Right clicking the OLD_BLOCK listing in the Blocks palette doesn't let me delete its nor do any palette menu options.
this is one of the annoying things about the semi-GUI sub-par-GUI-standards of Autocad for Mac 2024. Should be a right click and a palette menu option to delete something in a palette listing, like always it standard in all design software I can think of, including a bunch of 3D apps.
Etiquetas (2)
