paullimapa
en respuesta a: bretwieseler
Stick with your layer naming convention standards.
If you don't have any, time to look into setting up some.
But if you do & you typically use 3 character modifiers for other objects then it could be:
...-xrf-... = xrefs
...-vpr-... = vports
For 4 character modifiers then:
...-xref-... = xrefs
...-vprt-... = vports
Also, standardize if the letters should be all upper case, all lowercase and etc...
But if you don't ever plan on turning off or freezing the layers the xrefs or vports are placed then you can always leave them on the default Layer 0...though not recommended.
Paul Li
IT Specialist
@The Office
