belgborges
en respuesta a: belgborges
Thank you so much for moving my post to the correct forum!!
and thanks for the quick responde!!
I've attached a screenshot of the Autocad Lt where it shows 2024, I have no idea why it shows AutoCAD lt 2021 to you.
And when I was checking the items you suggested me to check, I was able to get the tick lines back and the numbers that were missing by turning on the layer 0.
What does the missing things have to do with layer zero if all my dimensions were under a layer called dimension!!
I have no clue!!
Thank you so much for your help!!
