pendean
en respuesta a: belgborges
@belgborges wrote:
...I can't figure it out why?...
...I also noticed that some dimensions (numbers) don't show when I print...
This is not the MAC forum, and your PDF was plotted from LT2021, not LT2024. So....?
I'll get you moved to the correct spot in the meantime. But confirm...
Which layer(s) in your file do you have set to NOPLOT?
which layer() in your file are frozen/turned off?
And if you start a blank new file and dimension in it, do you have this same problem too?
And in all other DWG files?
