paullimapa
en respuesta a: bretwieseler
commands that require a second prompt response to carry out unfortunately cannot in and of themselves be added in as a shortcut. But if you have a lisp function then that can be added in as a shorctut.
For example for Pedit Spline a simple lisp function could be:
(defun c:spf ()(if(ssget "I" '((0 . "LWPOLYLINE")))(command"_.pedit""_Spline""_Exit")(princ"\nNo Pline Selected."))(princ))
Now you can save this as spf.lsp & load it (load"spf") then you can add SPF as shortcut:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/To-Customize-Short...
Paul Li
IT Specialist
@The Office
