- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hello, I am wondering, is there is any way to alter the Mac Interface so it is easier to click on the dropdown menus for each object in the drafting tab? The dropdown menus are super TINY! I have to click on each dropdown menu multiple times before I am able to activate it. (See screenshot below)
If this isn't possible, then is there a way to prompt the command line to give me an object command that is NOT the default option? For example, can I tell the command line to give me a circle other than the default circle (tan tan radius)?
I'll appreciate any help!
Thanks!
-Selah
¡Resuelto! Ir a solución.
- Etiquetas relacionadas:
AutoCAD mac
Drop down menu
interface customization
mac interface
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @spotsanderU83HE ,
This problem has already been discussed on the Forum many times.
Please look for example here:
https://forums.autodesk.com/t5/autocad-for-mac-forum/lt2017/td-p/6746239
and here:
Yes, if you have full AutoCAD version you can create new command with AutoLISP.
On LT you can assign shortcut to one of the command macros with CIRCLE command.
Maxim Kanaev
Architect
MARSS
