maxim_k
en respuesta a: GKPByDesign
Hi @GKPByDesign ,
@GKPByDesign wrote:
Intel based i9 8 core 16 inch MacBook Pro, 32gb ram and 8 gb graphics,
I have the same MacBook model as yours, but with Intel i7.  I have not upgraded to Sonoma, I'm on Ventura.
In my case AutoCAD 2024 runs just fine.
>>>>I went from 2023.2 to AutoCAD 2024 to try and fix the problem
Did you import the settings when installing 2024 version of AutoCAD? If yes, try to Reset AutoCAD and don't import custom settings from previous version (if any).
What graphics engine is enabled in AutoCAD 2024? (General tab of AutoCAD Preferences window). If it is Open GL Core Profile - try to change it to Metal. Don't forget to relaunch AutoCAD after you change this.
What mouse do you use? Do you have the same problem with Trackpad?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
