katieannspratley
180 Vistas, 1 Respuesta
Drawing wont plot in grayscale or monochrome
Every time I try to plot in grayscale or monochrome it plots in colour instead. I have tried changing all the layer display colours, importing grayscale stb, which also does not work. I've attached pictures of what appears. I have also tried  convertpstyles and convertctb which doesnt work either.
Please help!
maxim_k
en respuesta a: katieannspratley
Hi @katieannspratley ,
While you are in the layout look at the Properties Palette and verify that you assign proper Plot Style table (nothing should be selected in the drawing):
Now double-click inside Viewport you want to plot in monochrome.
Go to Layers palette and change Plot Style for each Layer from "Normal" to the one you want:
Switch to the Layout and try to print.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
