10-20-2023
11:25 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-20-2023
11:25 AM
Hi @rsimx123 ,
Do you mean that on Mac when you double-click on attribute inside block with multiple attributes, it opens dialog for editing attributes, but double clicked attribute is not selected in it?
If yes, then you can:
- Use Properties Palette for editing attributes. Just select block and look at the Attributes section on the Properties Palette
or
- Double-click the attribute while holding down the Ctrl key. In this case you can edit attribute right "in place", without opening dialog. AutoCAD starts ATTIPEDIT command in such case.
Maxim Kanaev
Architect
MARSS
