maxim_k
en respuesta a: vojtech4CRNY
Hi @vojtech4CRNY ,
You need to update your AutoCAD LT with >>>>THIS<<<< Update.
Launch AutoCAD, click menu AutoCAD LT 2024 > Check for Updates. A notification banner will pop up with the latest update that is applicable to the current version. If nothing happens after you click Check for Updates, check the notification setting in your macOS preference and make sure the notification is enabled for AutoCAD LT for Mac. If the notification is already enabled, click the top right corner of the screen to open notification center, and you should see the notification on top of the notification center.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
