maxim_k
en respuesta a: alastair_leith
Hi Alastair,
>>>>Converting lines and layers by color and other ways are all referenced many times in the abstract, but never explicitly demonstrated in simple examples I can follow.
I'm not sure you're absolutely right. I think that you can find a sufficient number of tutorials on how to use plot style tables in AutoCAD. Maybe most of them are about AutoCAD for Windows, but the basic concepts are the same.
>>>When I plot using the monochrome plot style, most of my layers went to black in the PDF but some (say 3 or 4 of 15) stayed the colour they are in model space and paper space. Not clear to my why certain layers are in color and how I fix it.
This is because Color dependent plot style you have in your drawing uses only ACI (AutoCAD Color Index) colors - 256 colors from 0 to 255. Layers (objects) with True colors and Color Book colors are always plotted in color.
If you open Plot Style Table Editor, you will see only 256 colors you can use (left side of the dialog).
The Layers you mentioned have True Color assigned to they color property, so they will always plot in color.
>>>I can only get any kind of plot using "scale to fit". My model space is in millimetres and the objects I'm drawing for CNC are about 370 mm wide and 60 mm high, so I should be able to see them at 1:1 scale on a portrait A3 and fit them all in at 1:2 scale on a portrait or landscape A3 sheet of paper.....
When you use Page Setup for the Layout, you always need to follow some simple steps:
1/ Select printer - for PDF output in most cases you select one of AutoCAD PDF "plotters"
2/ Select Paper Size you need
3/ Always select Layout for "What to Print" option. Otherwise you will have problems with viewport scaling
>>>>>When I changed the DIMS layer from Cyan colour to something that was more legible in paper space against the white background (I choose a darker green/blue) the DIMS layer (my dimensioning) showed as black linework in paperspace. Was that random or what?
This is because you assigned monochrome plot style and selected "Display plot styles" option in Page Setup window.
>>>>Why didn't all the other layers show as Black on white in paperspace after attempting to print?
Please see my note about ACI colors above.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
