maxim_k
en respuesta a: alastair_leith
If you need different settings for different type of dimensions in one "master" dim style, you need create base style, then create individual sub-styles from it, then edit each of sub-styles.
In your case you can at first remove " suffix from the "Standard" dim style, then create Linear and Angular sub-styles, then edit Linear sub-style and add suffix to it.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
