- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi @alastair_leith ,
You can use command line version of DIMSTYLE command to create separate sub-style for angular dimensions.
Ensure that current dim style is STANDARD.
Start with changing DIMPOST System Variable to none - type point when AutoCAD prompts for DIMPOST value:
Command: DIMPOST
Enter new value for DIMPOST, or . for none <""">: .
Command:
Now use command line version of DIMSTYLE command (with dash before command name) to save new dim style with special name "Standard$2":
Command: -DIMSTYLE
Current dimension style: Standard Annotative: No
Current dimension overrides:
DIMPOST
Enter a dimension style option
[ANnotative/Save/Restore/STatus/Variables/Apply/?] <Restore>: S
Enter name for new dimension style or [?]: Standard$2
Command:
Now use command line version of DIMSTYLE command again to restore Standard dim style:
Command: -DIMSTYLE
DIMPOST
[ANnotative/Save/Restore/STatus/Variables/Apply/?] <Restore>: R
Enter a dimension style name, [?] or <select dimension>: Standard
Command:
Now use dialog based version of DIMSTYLE command to see the changes, you should see:
Maxim Kanaev
Architect
MARSS
