maxim_k
en respuesta a: alastair_leith
Hi @alastair_leith ,
Yes, you can create additional Dim Style for such Lind of dimensions, but in the "finished" version they used dimension text override method:
Select the dimension in "finished" version of the drawing and look at the Properties Palette:
The dim text is: %%C<> - this means that diameter symbol - %%C - added to the default text - <>
You can remove " from the angular dimension also by editing properties of the individual dimension (remove " from the prefix):
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
