v.guogis
322 Vistas, 5 Respuestas
(vl-file-systime) error
At first, sorry if it is not the right place to report bugs, but I really tired with looping forth and back on my ADN account by support links. So I guess developers can catch this post.
I am checking (vl-file-systime f) and get this error:
; error: no function definition: file-time-vector
ps. Help states it should be supported for macOS:
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-7F6A31B2-7D51-4C4D-B239-206F398D67CA
Regards, Vaidas
pendean
en respuesta a: v.guogis
@v.guogis wrote:
...ps. Help states it should be supported for macOS:
Your link is for the Windows OS version of AutoCAD.
MacOS AutoCAD 2024's HELP is here https://help.autodesk.com/view/ACDMAC/2024/ENU/?guid=GUID-CE2603B8-A003-4B1C-B1DD-3AB3A362A982
v.guogis
Thank you @pendean
However your links also show compatibility for macOS, see image.
pendean
@v.guogis wrote:
Thank you @pendean
I was just directing you to the correct weblink for the macos software.
If you want to share your actual LISP that reports the problem I'm sure someone around here can help dissect the trigger if they can replicate it too.
v.guogis
en respuesta a: pendean
Just copy-paste into a command line and select any file:
(vl-file-systime (getfiled "Select any file" "" "*" 8))
maxim_k
Hi Vaidas,
@v.guogis
Yes, this looks like a bug in AutoCAD for Mac.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
