christophk
395 Vistas, 3 Respuestas
LISP in Autocad Lt for MacOS?
Hi
Does AutoCAD 2024 Lt offer Lisp functionality?
If it does, I don't get it to run.
I can drag and drop a LISP into Autocad window on MacOS:
Command: (LOAD "/Users/user/Templates/ACAD/LISP Scripts/Bisector.lsp")
but then I can't use the command "bi" for Bisector.
(just an example).
Thanks a lot in advance for your answer.
Etiquetas (2)
Etiquetas (1)
ВeekeeCZ
en respuesta a: christophk
Although LISP was made available in LT, platform limitations still persist. Mac cannot take advantage of Windows Active-X features.
BISECTOR uses vlax-curve* functions so it won't work in AutoCAD LT 2024 for Mac. But it would be in AutoCAD LT 2024.
christophk
Thank you @ВeekeeCZ !
That is a great hint to understand the limitations and now I know what to look for and what to avoid.
Thanks again and have a good weekend,
Chris
pendean
@Anonymous Autodesk did not enable LISP for LT2024 for MAC. "limitations" are not as narrow as described since LISP is not there at all https://forums.autodesk.com/t5/autocad-for-mac-forum/autocad-lt-for-mac-and-autolisp/m-p/11887599#M45636
and https://forums.autodesk.com/t5/autocad-for-mac-forum/autocad-lt-for-mac-and-autolisp/m-p/11887650#M45637
Sorry.
