08-01-2023
10:40 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
08-01-2023
10:40 AM
@mgnrr007 wrote:
>>>>>The heavy lines sit over other lines and obstruct the drawing.
You need to turn off the display of lineweights with this button on the Status Bar: DOES THIS NEED TO HAPPEN EACH TIME ONE TOGGLES BETWEEN PAPER SPACE AND MODEL SPACE? IT USED TO BE THAT MODEL SPACE WAS DEFAULTED TO THE DEFAULT LINE WEIGHT OF MAYBE ONE PIXEL? ALWAYS THIN IN MODEL SPACE...
It is a session wide all-tabs all-locations-in-a-dwg-file on/off switch, there is no built-in "only do it here but not there" option. That's always been the case, no variation in earlier year versions. Perhaps back in the day you relied on "display Plot Style" setting for your layout pagesetups, and not actual LWEIGHT settings?
