mgnrr007
en respuesta a: mgnrr007
HI MAXIM,
THANK YOU AGAIN.
First of all - to be able to use images in your answers and attach any documents, you need to use a browser - ie. respond not by e-mail, but here on the Forum. UNDERSTOOD THANKS
Can you share your drawing here on the Forum? YES WILL TRY TO DO THIS. MY FONTS ARE GONE TOO SO WON'T LOOK FULLY CORRECT THERE BUT ONE THING AT A TIME
If yes, please create an archive of the drawing and dependency files (CTB for instance) with ETRANSMIT command and attach it to your reply here on the Forum.YES WILL TRY TO DO THIS.
It seems to me that you mixed imperial and metric settings in your drawing and this explains all the problems you have. MAKES SENSE.
What is your preferred units? IMPERIAL What is 1 AutoCAD unit in your drawing in the real world? I DON'T UNDERSTAND THIS QUESTION SORRY
>>>>>The heavy lines sit over other lines and obstruct the drawing.
You need to turn off the display of lineweights with this button on the Status Bar: DOES THIS NEED TO HAPPEN EACH TIME ONE TOGGLES BETWEEN PAPER SPACE AND MODEL SPACE? IT USED TO BE THAT MODEL SPACE WAS DEFAULTED TO THE DEFAULT LINE WEIGHT OF MAYBE ONE PIXEL? ALWAYS THIN IN MODEL SPACE...
