- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Thanks Maxim,
Given your reply, I decided to test it out with two new blocks with simple geometry inside, each set of geometry (internally) on the different layers ( it worked as intended).
I checked my old block again (It definitely doesn't work). This is a dynamic block with 4 embedded blocks on different visibility states i.e its a bathtub block with different sub-blocks for long elev, short elev, section, and plan.
This made me check another old block with simpler geometry. This worked. (edit actually not a dynamic block, checking that now)
Edit: Have now checked another old dynamic block (that has a stretch parameter and visibility) but no embedded blocks, this also worked.
So the problem seems to be with embedded blocks, any thoughts?
Thanks again
Jo
Edit: Not very useful in my case but I've found that if there is an instance of the embedded (nested block) outside the block when I do the combine, it changes to the new layer, the embedded one does not. However if I then hit regen, the embedded one updates to the correct layer. Regen doesn't work otherwise.
