info60
358 Vistas, 4 Respuestas
AutoCAD LT 2016 Mac - Mac OS High Sierra - Start Failure after Replacement of SSD
Hi out there,
Ich had to replace the SSD in my MacBook Pro 15" (mid 2015) because of lack of free space. Now, the machine runs fast again. All programms run without problems except AutoCAD LT Mac 2016. Can anybody give some help?
How can I "get in" gain? I suggest, some of you faced this problem before ...
Andreas, Berlin
paullimapa
en respuesta a: info60
That’s a very old version. Even if you can access the installation files, Autodesk will not allow you to activate it. I suggest subscribing to the latest version
Paul Li
IT Specialist
@The Office
pendean
Greetings @info60
High Sierra requires you to install the AutoCADLT for Mac Update 2016.5: did you do that
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/autocad-and-mac-os...
info60
en respuesta a: pendean
Thanks for your reply.
I have this patch downloaded, but I am not really sure wether it is installed. I cannot check it, because acad failed to start ...
But High Sierra orked fine since years ...
pendean
@info60 "downloaded" means nothing if that is all you did, sorry.
Installing the update is the best way to ensure it is there: you can repeat it if you are unsure. https://iboysoft.com/news/how-to-install-software-on-a-mac.html#:~:text=Mac%20App%20Store-,Mac%C2%A0...
