james7
653 Vistas, 1 Respuesta
SPACEBAR NOT WORKING FOR ENTERING COMMAND ALL OF.A SUDDEN
Hi
Been using AUTOCAD For Mac on MACBOOK PRO M1 MAX for a little while now without issue.
I have just used "Shift + space" to cycle through lines that are overlayed on top of one another
since doing so I find that hitting space to enter a command - e.g. TR (trim) and space doesn't enter the trim command
If i do "TR(trim) and hit enter key it works just fine.
Never had this happen before and dont know the variable to fix whatever system setting has changed.
Any help would be much appreciated
James
maxim_k
en respuesta a: james7
Hi James,
 @james7
There is a bug in AutoCAD 2024 for Mac. If you have redefined standard shortcut(s) with CUI command, spacebar stops working correctly:
https://forums.autodesk.com/t5/autocad-for-mac-forum/2024-esc-key-always-runs-the-new-command/m-p/11...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
