- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi all,
I'm experiencing a major issue with my AutoCad.
Some commands are not working at all, neither when I type them out or when I click on the respective icons. Whenever I try, the software says "Unknown Command. Press F1 for Help". These include MATCHPROP, MTEDIT, UNITS, BLOCK EDITOR, and OPTIONS/PREFERENCES. Most of the solutions found online state that you need to change settings in the OPTIONS Dialog Menu to fix the other commands, but I cant open that menu because OPTIONS is one of the commands that need fixing.
I tried resetting Autocad to default several times, as well as uninstall and install anew.
I cannot think of a reason why this happened, other than my subscription was ending, and I renewed it earlier because it was acting up.
Would greatly appreciate any insight on this, as I'm growing pretty frustrated and the support staff I contacted so far was not helpful.
¡Resuelto! Ir a solución.
