julieE3FMG
555 Vistas, 6 Respuestas
my shortcuts doesn't function in autocad for mac
hello
my shortcut doesn't function
command+Z = quit
command+A = quit
command+Q = select all
command+S = quit
HELP please I can't work
[ The subject line of this post has been edited for clarity by @pendean Original: shortcut ]
Etiquetas (1)
paullimapa
en respuesta a: julieE3FMG
I don’t believe AutoCAD supports keyboard shortcuts using Windows Command key. Only Ctrl or Shift combinations on the keyboard is supported. Follow along on this video tutorial on how to define keyboard shortcuts
Paul Li
IT Specialist
@The Office
julieE3FMG
en respuesta a: paullimapa
I m on mac, it’s command=apple
I already check shortcut and they are ok
Out AutoCAD shortcut are ok too
paullimapa
In that case you should post this in the AutoCAD Mac forum
Paul Li
IT Specialist
@The Office
WeTanks
Please check below.
https://www.autodesk.com/shortcuts/autocad-for-mac#:~:text=most%20recent%20undo-,Cmd%2DZ%20or%20Ctrl...
https://www.autodesk.com/shortcuts/autocad#:~:text=dynamic%20input%20mode-,Manage%20Workflow,-Ctrl%2...
If all else fails, short of renstalling Autocad, do a "Reset Settings To Default
We.Tanks
A couple of Fusion improvement ideas that could your vote/support:
図面一括印刷
maxim_k
Hi @julieE3FMG ,
Please look at these threads:
https://forums.autodesk.com/t5/autocad-for-mac-forum/autocad-lt2024-keyboard-shortcut-problem-with-a...
https://forums.autodesk.com/t5/autocad-for-mac-forum/autocad-lt-for-mac-cmd-z-undo-bug/m-p/11907113#...
The developers are working on a fix.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
Hi @julieE3FMG ,
The Update, which fixes this issue is ready:
for AutoCAD 2024:
https://help.autodesk.com/view/ACDMAC/2024/ENU/?guid=AUTOCAD_MAC_2024_0_1_FIXED_ISSUES
for AutoCAD LT 2024:
https://help.autodesk.com/view/ACDLTM/2024/ENU/?guid=AUTOCADLT_MAC_2024_0_1_FIXED_ISSUES
You can use Check for Updates from menu AutoCAD to download it.
Do not forget to turn on Alerts for AutoCAD 2024 in Notifications section of macOS System Preferences.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
