05-07-2023
01:58 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-07-2023
01:58 PM
Hi @jsclage ,
Looks like you need to follow the recommendation in the alert - move the objects to another layer in one of the blocks that are used in the drawing.
You can use "Non purgeable items" tab of PURGE command to find out which blocks use a layer that you can't delete.
In the example below the layer "WALL" is assigned to 16 lines inside block and cannot be removed from the drawing:
Maxim Kanaev
Architect
MARSS
