maxim_k
en respuesta a: federico_zanon
Hi @federico_zanon ,
Assuming that you have Google Drive folder on both PC and Mac and you attach External Reference from this Google Drive folder on PC (Windows), you cannot use XREFPATHMAP (mapping the server path between Windows and Mac feature) in this case.
You can use XREFPATHMAP only if you have access to the same network drive on PC and on Mac.
For example:
- you have network drive on PC mapped as Y: drive and you attached drawing from the "_TMP" folder on that Y: drive, the saved path of the Xref on Windows side is Y:\_TMP\Drawing1.dwg
- you have the same network drive on Mac connected as "/Volumes/Public"
in this case you cam map "Y:" to "/Volumes/Public" in the Server Path Mapping window:
And Xref on Mac side will be resolved automatically.
For Google Drive as a local folder you need to resolve Xref manually with the External References palette.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
