gokcen_bagci
563 Vistas, 8 Respuestas
Glitch in view Autocad
The solid masses in drawing can not be deleted by REGEN or FLATTEN. The visual styles is 2DWIREFRAME and at the top view. How can I fix this?
Etiquetas (6)
Valentin-WSP
en respuesta a: gokcen_bagci
@gokcen_bagci ,
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
pendean
Is this a problem in ALL of your files, or just this one?
If just this one, did you try to fix it yet? RECOVER command, copy/paste into a new blank template file, WBLOCK out the content to a new file, or... just share it here.
If this happens in ALL of your files, confirm your MacOS version and Apple laptop/PC/device make/model please.
maxim_k
Hi @gokcen_bagci ,
Looks like these "solids" are graphics system glitch.
Try to change Graphics engine on the General tab of AutoCAD preferences from Metal to OpenGL Core Profile.
Relaunch AutoCAD.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
gokcen_bagci
en respuesta a: Valentin-WSP
My problem was with all files so backup does not work but thank you.
gokcen_bagci
en respuesta a: maxim_k
I can not thank you enough. It worked. I tried other files and they open without problems as well.
gokcen_bagci
en respuesta a: pendean
I figured it out thanks to comment below but thank you!
wei503
Hi @gokcen_bagci , what is the graphics card on your Mac?
Wei Ma
AutoCAD QA Manager
gokcen_bagci
en respuesta a: wei503
It is integrated GPU. Apple M1, Metal GPUFamily Apple 7.
