04-09-2023
12:35 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
04-09-2023
12:35 AM
Hi @gregoran ,
You can leave your feedback about AutoCAD LT 2024 for Mac here:
https://www.autodesk.com/company/contact-us/product-feedback
>>>>>2024 keeps changing to requiring the shift key to add objects to selection regardless of how many times i have changed it..even when changing drawings
Yes, I can confirm this bug.
Meanwhile while we are waiting for a fix from Autodesk, you can try this workaround:
1/ Create script which changes PICKADD System Variable (don't forget to add a space after 2):
PICKADD 22/ Launch AutoCAD with Terminal command:
/Applications/Autodesk/AutoCAD\ LT\ 2024/AutoCAD\ LT\ 2024.app/Contents/MacOS/AutoCAD\ LT\ 2024 -b YOUR_PATH/LT.scrwhere YOUR_PATH - is the path to LT.scr script file with the contents I mentioned above.
You can use the same workaround for SAVETIME System variable if AutoCAD resets it on your Mac.
Maxim Kanaev
Architect
MARSS
