jamesPDEAU
265 Vistas, 2 Respuestas
Project Manager Publish sheet to pdf with custom sheet name
Hi there,
I am using AutoCAD LT for Mac. Is there a way, using Project Manager, to publish a set of drawings from a sheet set with a custom filename format? I would like the end pdf result to be:
<ProjectNumber>-<ProjectPhase>-<LayoutNumber>-<RevNumber*>-<Title>.pdf
*I input a letter in this field rather than a number
So:
123-P-01-A-Sheet Title.pdf
Currently it just exports as 01-Sheet Title.pdf by default.
Is there a way to edit it so that it references these fields in the filename?
James
Etiquetas (2)
