SNOODS21GRL
1033 Vistas, 1 Respuesta
Converting .txt to .scr on textEdit on mac
Hello! I am having trouble having autocad on my mac recognize a .scr file. It was originally a .txt and like one would do on windows, i simply renamed it to .scr on TextEdit but neither autocad nor textedit recognized it. I have tried other apps to rename this txt and "save as" a .scr but to no avail.
Any tips on how to convert my .txt file to .scr for autocad on a mac would be appreciated. Thank you
Etiquetas (1)
maxim_k
en respuesta a: SNOODS21GRL
Hi @SNOODS21GRL ,
If .txt file actually is AutoCAD script file you only need to rename its extension from .txt to .scr in Finder.
Then you can open it in AutoCAD.
If you need to edit the contents of this file before using as script in AutoCAD, you can open .txt file in TextEdit app, edit and save it, then rename the extension. Furthermore - you can edit even .scr file in TextEdit. Right-click on the .scr file in Finder and select "Open with" from the context menu, select TextEdit.app and it will be opened in it.
Edit file and simply save it.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
