limnakhau
en respuesta a: arnasvel
I'm trying to scale a dynamic block based on the numeric value of an attribute.
I suspect one of these is the right approach:
  • How do we set a Property Lookup Table entry from an Attribute?
  • Or set a Block Properties Table item based on an Attribute?
  • Or set an Attribute value as a global variable https://omegle.onl/?
Specifically, I'd use the annotation scale, which can be easily assigned to an attribute by the CANNOSCALEVALUE system parameter.
