alabrk
272 Vistas, 4 Respuestas
Autocad crashes when publishing my sheet set
Since a few days, I am trying to publish a sheet set that I created in one of my projets. My sheet set is created using 3 different drawing files. Usually, I have no problem publishing but with this one file, there is an issue and I can't figure out which it is. I captured the message that I receive when autocad crashes and attached the dwg file that is corrupted.
What can I do to resolve the problem?
Thank you very much for your help!
pendean
en respuesta a: alabrk
Do you have the latest updates installed, this one? it is highly recommended https://knowledge.autodesk.com/support/autocad-lt-for-mac/learn-explore/caas/CloudHelp/cloudhelp/202...
HTH
maxim_k
Hi @alabrk ,
I tried to publish your drawing after I added it to the new Project - no issues.
But I noticed that your drawing has Xref, which is missing, so I can't fully test it. In addition I don't have your Project settings at hand - project and layout custom properties, etc. (if any)....
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
alabrk
en respuesta a: pendean
That was it. Thank you!
alabrk
en respuesta a: maxim_k
My autocad needed an update. That's why it crashed when I tried publishing.
Thank you for your help!
