maxim_k
en respuesta a: crlarchitect
Hi @crlarchitect ,
At first - about the case when you use LAYOUT command.
You are missing one step - you need to confirm which layout you want to rename:
Command: LAYOUT
Enter layout option [Copy/Delete/New/Template/Rename/SAveas/Set/?] <set>: r
Enter layout to rename <Layout1>: <---Hit Return here to confirm that you want to rename layout with "Layout1" name
Enter new layout name: A-101
Layout "Layout1" renamed to "A-101".
Command:
About the first issue.
When I right-click on Layout tab and select "Rename":
AutoCAD opens text field, where I put new name:
Now I hit Return and get Layout renamed:
Do you use the same steps?
You can also double-click on Layout tab name to start renaming it.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
