maxim_k
en respuesta a: bret_wieseler
Hi Bret,
 @bret_wieseler
This is "by design" - AutoCAD hides multileader arrowhead when the first leading segment is less than twice the length of the arrowhead.
But there is a workaround.
Please look at the attached DWG - try multileader inside yellow rectangle.
Does it work for you?
If yes, then idea of the workaround is to make block elements four times bigger then it should - in your case I scaled objects inside arrowhead block 4 times.
Now you need to edit multileader style and set the scale of the arrow to 1/4:
 That is all.
The new multileader style in your drawing is MLDR-REFR-DETL-1 and arrowhead block for it is REFR-ARRW-1.
All kudos should go here:
https://forums.autodesk.com/t5/autocad-forum/multileaders-disappear-with-a-short-leader/m-p/8050222#...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
