maxim_k
en respuesta a: arnasvel
Hi Arnas,
You can make this attribute visible by editing block definition:
- Open tree block in Block Editor, select attribute and uncheck Invisible property in the Properties palette:
If you need, you can also adjust thee position of this attribute inside block.
- Save block, close Block Editor,
- Use ATTSYNC command to synchronise attribute definition change.
Now this attribute is visible in all block insertions.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
