kmarmstrong
751 Vistas, 4 Respuestas
Is there no LAYTRANS in AutoCAD for Mac?
Looking to use LAYTRANS command and come up short. Is there a workaround? I don't need LAYMERGE... I'm looking for LAYTRANS or the same way of getting the outcome (creating new layer and merging layers to it).
@kmarmstrong
The topic title has been edited to improve findability by @alina.balkanskaia. Original: Is there no LAYTRANS in mac?
maxim_k
en respuesta a: kmarmstrong
Hi @kmarmstrong ,
LAYTRANS is not available in AutoCAD for Mac as well as other commands related to Drawing Standards.
Can you explain in more detail what do you want to achieve?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
alina.balkanskaia
Hello, @kmarmstrong! I just accepted your post's answer as a solution, knowing that it's an appropriate answer that will save other users time. If this is not correct, please reply to my post so I can unmark the solution so you can continue the discussion in the thread. In that case, post more information on your request! No action is required if the answer was really helpful to you.
Alina Balkanskaia
gabe6EJDM
en respuesta a: alina.balkanskaia
so how do i convert layers to other layers?
maxim_k
en respuesta a: gabe6EJDM
Hi @gabe6EJDM ,
You can use -LAYMRG command to merge selected layers into a target layer.
https://help.autodesk.com/view/ACDMAC/2024/ENU/?guid=GUID-7D66940F-EC67-4DEC-89BC-82B887EABD6E
https://help.autodesk.com/view/ACDMAC/2024/ENU/?guid=GUID-0976544F-76F9-444C-86D3-91BEAABECCD8
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
