- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I've been having an issue with PDF files generated with AutoCad LT for Mac 2019. They appear fine when viewed in Preview on my Mac (the sender), but when viewed in Preview at the receiving Mac, the mtext elements have boxes surrounding the text. The PDF files however appear normal if viewed with Acrobat Reader at the receiving Mac. Please see the attached screen shots of the various PDF files. I have generally been generating the PDF files using my HP 1320 printer configuration, but the same has happened if I use the AutoCAD PDF (High Quality Print).pc3 printer configuration. Has anyone else had a similar problem and have a solution other than the obvious to tell the receiver to use Acrobat Reader? Thanks.
The topic title has been edited to improve findability by @alina.balkanskaia.
¡Resuelto! Ir a solución.
