- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hello, My first pdf import.
The scale of the original drawing that was PDF'd is 1/4" = 1'-0", I set the scale for this drawing at 1/4" = 1'-0" . The import scale was 1.00.
When I draw a line it is full scale, I can't draw at 1/4" scale.
Drawing attached.
I would very much appreciate any help!
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @JEFFJW9BB ,
The scale you set is the annotation scale, it only affects the annotation scale - text size, linetype and hatch scale, and so on.
If you need to draw at 1/4" scale, you need to scale all geometry in your drawing at 1/4 scale.
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thank you for your reply.
I select all geometry then use the SCALE command. I thought to go from 1:1 to 1/4 scale the scale factor would be 0.25 but no. I tried the inverse, 4, and it got bigger, good, but not correct. How do you calculate the scale factor to go from 1:1 to 1/4" = 1'-0"?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I googled around and found that the scale factor is 48. It worked!
Thank you so much for your valuable assistance!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
1/4" = 1'-0"
0.25 : 12
1 : 48
Maxim Kanaev
Architect
MARSS
