maxim_k
en respuesta a: helloWYGL9
Hi @helloWYGL9 ,
From your screenshots in the second post I see that Regular typeface in 2019 and in 2022 versions looks different in Text Style window. Most definitely different Josefin Sans font versions are used in 2019 and 2022 versions.
Do you have Josefin Sans font only in one place on your Mac?
It should be placed only in ~/Library/Fonts folder.
Do you have another instance of Josefin Sans font inside
"/Applications/Autodesk/AutoCAD 2019/AutoCAD 2019.app/Contents/Resources/Fonts/ttf" folder?
If yes, then AutoCAD 2019 uses Josefin Sans font from that folder inside AutoCAD application folder, but AutoCAD 2022 uses another version of Josefin Sans font from ~/Library/Fonts folder.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
