ROBERTLESLIE3622
206 Vistas, 1 Respuesta
Seeing Double dimension text in ACAD LT 2023
I had an unexpected result when I changed DimStyle settings. Instead of a single dimension text there are two of them, one over the other. Tried a reset and changing dim styles, but neither worked. Need help to correct this.
Etiquetas (1)
maxim_k
en respuesta a: ROBERTLESLIE3622
Hi @ROBERTLESLIE3622 ,
Please verify that you accidently turn on Tolerances in the Dimension Style for the dimensions you have in the drawing:
https://help.autodesk.com/view/ACDMAC/2023/ENU/?guid=GUID-BE52ACEE-A046-412D-AEC8-593B9DEB674D
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
