- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I just tried solution #1 and #3 and it didn't work.
I am not sure what the subscription renewal would have to do with it, but that is the only thing that has changed so figured I should include it in case someone else had a similar problem.
Also, I am working on a Mac.
When I try to type a command with the keyboard, for example "L" to draw a line, the command box that usually appears near the cursor just flashes - I can't type anything it just appears for a second and then disappears. My only option is to type a command in the main command box every time I need to do something.
"Are your PICKFIRST and PICKADD variables set to the defaults listed in HELP in your LT version?"
I am not familiar with this, what should the defaults be?
Should I try to uninstall and reinstall the software?
