10-27-2022
07:16 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-27-2022
07:16 AM
Hi Sarah,
The block consists of objects located on layer 0, this is a common practice:
So when you lock layer 0 - you cannot edit block attributes as they are on the locked layer inside block. AutoCAD gives you an alert in the Command window: "The object is on a locked layer."
So you need to avoid locking layer 0 because it's kind of a special layer in AutoCAD.
Maxim Kanaev
Architect
MARSS
