- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I have an annotative block set up which has suddenly stopped working in one drawing only. The enhanced attribute editor is not opening when I double click on the block. Instead it's saying 'select a block' and it won't select my block. I've checked other drawings and they are working fine.
In the block pallet it's saying that the block is annotative and dynamic but in the block attribute manager is has 'no' against it (see image) but there doesn't seem to be an option to change this.
What else should I be checking?
The topic title has been edited to improve findability by @alina.balkanskaia. Original: annotative block
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @sophieEK ,
Please check that your annotative block is not nested inside another block.
As about the record in the Block Attribute Manager- it shows that on of the attributes inside this block doesn't have annotative property assigned.
Can you share the problem drawing with this block here?
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I've literally just figured it out - I had layer 0 locked. The block is on a different layer but it obviously has some kind of link to layer 0. It's now working fine ![]()
Thanks for your help though. Be great if someone could explain how that works for future ref......
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi Sarah,
The block consists of objects located on layer 0, this is a common practice:
So when you lock layer 0 - you cannot edit block attributes as they are on the locked layer inside block. AutoCAD gives you an alert in the Command window: "The object is on a locked layer."
So you need to avoid locking layer 0 because it's kind of a special layer in AutoCAD.
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thanks Maxim, I wasn't seeing the locked layer warning either as I'd reduced the command line. Thanks for explaining ![]()
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
