bretwieseler
418 Vistas, 4 Respuestas
Load default scale list?
I manage the Autocad installation in a small office and I'm wondering if there is a way to load the default scale list into AutoCAD rather than having to manually enter them.
Thank you.
-Bret
3.6 GHz 8-Core Intel Core i9 | 13.6.1 | AutoCAD LT for MAc 2024.1
Etiquetas (3)
Etiquetas (1)
maxim_k
en respuesta a: bretwieseler
Hi @bretwieseler ,
You can use SCALELISTEDIT command to Reset Scale list to the defaults: pick on the Gear button and select Reset:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
bretwieseler
en respuesta a: maxim_k
Thanks Maxim, but I was looking for a way to load a customized "default" list.
-Bret
maxim_k
You can:
- attach drawing with your custom scale list to the drawing you want to import the sheet into.
- detach this Xref.
- uncheck "Hide Xref Scales" in the list of scales on the Status Bar:
- use imported scales - you can also edit their names after detaching Xref
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
bretwieseler
Thanks Maxim.  That's a fantastic idea!
-Bret
