maxim_k
en respuesta a: Anonymous
Yes, I see the problem. Actually it is knowing problem when printing transparency from autoCAD directly to the physical printer.
There are two workarounds:
1/ Use build-in AutoCAD PDF (xxxx).pc3 Printer in Print window to create PDF file. You can use "Preview" button to generate temporary PDF file and print it from your PDF viewer to physical device.
2/ Edit Solid hatches: convert them to Gradient Hatches with the same values for Color 1 and Color 2.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
